kotsoss
- Joined
- Apr 20, 2013
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,315
I want to obtain the reflection coefficient using FFT in a transmission line, the source was excited with a Gaussian pulse. Τhis is an abstract from a paper that I have as guide:
"In order to obtain the reflection coefficient, the coaxial cable was excited with a Gaussian pulse of the form
Vs (t) = exp(-(t − 3Ts)/Ts)
Ts =1/2fmax
which was added at every time step to the voltage node located at z = 6.340 cm. The number of time steps as well as the step size
that were used are given in the first row of Table III. The voltage waveform was sampled at the node located at z = 8.622 cm
in order to compute the reflection coefficient Γnum from a discrete Fourier transform of the incident and reflected pulses."
I have calculated the reflection coefficient but I think the results are wrong. Anyone knows whats wrongs? Do you have any code that I can see? It would help me very much.
So here is my code:
Ts =1/2fmax
So here is my code:
st=100; %trasmission line of 100 length
i=zeros(1,st);
v=zeros(1,st);
dz=0.01;
l=250;
dt=dz*sqrt(l*c);
for k=1:49
c(k)=0.1;
end
for k=50:st
c(k)=0.3;
end
%matrixes for the storaging the values of the incident and reflected waves.
vr=zeros(1,18);
vi=zeros(1,18);
vin=zeros(1,18);
vref=zeros(1,18);
sun=zeros(1,18);
r=0;
y=0;
for n=1:97
t=n*dt;
for k=1:st-1
v(k)=v(k)-dt/(c(k)*dz)*(i(k+1)-i(k)); %calculate the voltage
end
v(st)=0;
fs=exp( - ((t-1)/(0.3))^2 ); %gaussian pulse
v(1)=fs;
for k=2:st
i(k)=i(k)-dt/(l*dz)*(v(k)-v(k-1)); %calculate the current
end
if n>=23 && n<=40 %the time period where the incedent wave pass from the node k=21
r=r+1;
vi(r)=v(21); %save the values of the voltage of the incedent wave in a matrix
vin(r)=fft(vi(r)); %calculate the fft of the incedent wave
end
if n>=80 && n<=97 %the time period where the reflected wave pass from the node k=21
y=y+1;
vr(y)=v(21); %save the values of the voltage of the reflected wave in a matrix
vref(y)=fft(vr(y)); %calculate the fft of the reflected wave
end
%plot(v);
axis([0 st -2 2]);
title(['Time = ',num2str(n)]);
frame = getframe;
end
sun=abs(vref./vin); %calculate the reflection coefficient
plot(sun)
