In my csh run file. I setenv the Cadence Version 6.1.6.140 but when it starts succefully, I shows version 6.1.6.500.14.
There are many warning about envSetVal as well. Could anyone tell what happens? Thank you.
Simply, invalid environment variables are defined in system "cdsinit" or "cdsenv" or your ".cdsinit" or your ".cdsenv".
That's all.
See log file of Virtuoso.
I think when I run Virtuoso 6.1.7, there are some variables which are generated. Then when switching back to 6.1.6, these variables are invalid.
This is not problem I think.
I copy the running file, .cdsinit file from my senior. I thought the virtuoso version should be the same but it's not. I don't know why there is different. Could you give some guess for this situation? Thank you.
1. I've already posted.
2. I cannot see the content because he in the different host.
3. Only this matters
when( isFile("~/.cdsinit") load("~/.cdsinit"))
Other things about simulation and calibre setup.
There is no .cdsinit file in ~/ foler.
4. 5. Because the sensitive contents, I cannot post here. Could you tell me the specific parts which you want to see?
I copy the .cdsinit file from my senior working folder. I can access to his working folder (because his and mine are the same directory), but I cannot access to his home folder (~/). Please take a look at this command.
Thank you for your patience and kind help. As I said, I cannot provide FULL file and I just want to hear the guess and suggestion. I do know a bit about cadence configurations but I don't know what is problem in this case, so I ask.
