Analogworld
spectre cadence 6.0 ic5033
Hi All,
Someone has posted this topic before, but no one has ever provided a solution to solve this issue yet. I am now having the same situation that Spectre can not find the transistor model in the correctly pointed tsmcrf library. I am sure that the require Spectre model file is setup correctly, and it works fine for the other devices (i.e. well or poly resistors) in the same file location. It just not work on the transistor models. Why?
I even looked into the pointed model file "rf018.scs" that provided by TSMC's cadence design kit. However, the transistor model named "nmos2v" (as shown in the error message), doesn't even exsit in the Spectre model file! And Cadence do not let me change the transistor's model name from the property menu.
Is there a problem with the TSMC's Cadence design kit? I doubt it though! Then how should I get it to work? Did anyone exprience this problem before? Any help would be greatly appreciated.
Spectre.out error message :
Command line:
/Cadence/IC5033/tools.lnx86/spectre/bin/spectre -env artist5.0.0 \
+escchars +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre0_3023_3 -format psfbin -raw ../psf \
input.scs
spectre pid = 3618
Loading /Cadence/IC5033/tools.lnx86/spectre/lib/cmi/3.0/libinfineon_sh.so ...
Loading /Cadence/IC5033/tools.lnx86/spectre/lib/cmi/3.0/libnortel_sh.so ...
Loading /Cadence/IC5033/tools.lnx86/spectre/lib/cmi/3.0/libphilips_sh.so ...
Loading /Cadence/IC5033/tools.lnx86/spectre/lib/cmi/3.0/libstmodels_sh.so ...
spectre (ver. 5.0.33.031705 -- 17 Mar 2005).
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
Security, Inc.
Simulating `input.scs'
Compiling ahdlcmi module library.
Finished compilation in 1 s (elapsed).
Installed compiled interface for bsource_1.
Installed compiled interface for bsource_2.
Installed compiled interface for bsource_3.
Installed compiled interface for bsource_5.
Installed compiled interface for bsource_41.
Installed compiled interface for bsource_42.
Installed compiled interface for bsource_56.
Installed compiled interface for bsource_68.
Installed compiled interface for bsource_69.
Installed compiled interface for bsource_83.
Installed compiled interface for bsource_85.
Installed compiled interface for bsource_90.
Installed compiled interface for bsource_101.
Error found by spectre during circuit read-in.
input.scs: M0 is an instance of an undefined model nmos2v.
spectre terminated prematurely due to fatal error
Hi All,
Command line:
input.scs
spectre pid = 3618
Security, Inc.
