Cadence SKILL script fails
navarromoral
Junior Member level 1
Spain
Hello all!!
I am trying to write a script to automate some simulations. I want to change the frequency, common mode and differential voltage and then save the eye diagram.
My problem is that, somehow, the results of the plots are not always correct, that is, sometimes the result is right, sometimes I have an empty diagram, sometimes half the diagram, ... Is there a command to reset everything (variables, data, ...) so consecutive simulations are completely isolated?
Please, if you can think of a cause, let me know.
Here is the script I wrote:
vdiffrange='(0.05 0.1)
vcmrange='(0.0 1.65 2.4)
freqrange='(5e8 1e9)
freqnames='("500MHz" "1GHz")
count=1
ndata=5000
foreach(f freqrange
	clearAll()
	per=1/f
	dur=ndata*per/2
printf("\nper:%.10f dur:%f" per dur)
	foreach(i vcmrange
		foreach(j vdiffrange
			ocnWaveformTool( 'wavescan )
			simulator( 'spectre )
			design(...)
			resultsDir( ...)
			modelFile(...)
delete('desVar)
delete('analysis)
			analysis('ac ?start "1"  ?stop "1e10"  ?dec "50"  )
			analysis('dc ?saveOppoint t  )
			analysis('tran ?stop dur*1.1 )
			desVar( "period" per/2 )
			desVar( "Vdata" j )
			desVar( "Vcm" i )
			temp( 27 )
			eye = eyeDiagram((VT("/Vop") - VT("/Von")) 0.0 dur per)
			run()
			plot( eye ?expr '( "eye" ) )
			hardCopyOptions(?hcOutputFile sprintf( nil "eye_%s_Vcm%.3f_Vdiff%.3f.png" nthelem(count freqnames) i j ))
			hardCopy()
			deleteSubwindow()
printf("\nper:%f dur:%f" per dur)
	count=count+1
Thank you very much!!
