cadence pss/pnoise analysis issue
khorlipmin
Member level 3
pss cadence
Hi I am having this problem with pnoise analysis.
since pss is to be carried out before pnoise, the netlist always generate pnoise first followed by pss. thus the simulator will flag error and ignore the pnoise analysis. The only solution I got now is to manually reassign pnoise to follow pss analysis in the netlist. Anyone is experiencing the same problem?
pnoise analysis
See Cadence help document
cadence pss
cadence has a lot of bugs and issues. if can set it maually, just do that!
pss pnoise
I see, thanks man
pnoise cadence
In Virtouso ADE, select menu ->Setup->Environment
then in Analysis Order, put your desired order e.g. dc pss pnoise
    khorlipmin
cadence pnoise
thanks man you are the best
