Beardolphinaries
After I draw the layout, check the DRC, and extractd, then can I just run simulatiion from Analog Environment and this is the post layout design, isn't it? Thanks
Layout pins names must be identical with schematic pin names. Otherwise, your LVS will report the error message (but you will still be able to run RCX procedure).In layout, can I add 'vdd!' and 'gnd!' and power supply and ground? It seems doesn't work. When I change these global to normal vdd and vdd label, it works again.
