Cadence Alegro 16.3 - Is there a way to add more vias to a trace using pcb design
bigpcman
Is there a simple way using the pcb trace editor to add more vias to a trace to increase the copper connectivity between two trace layers?
praveenlb
Full Member level 3
Bangalore
No you have to do it manually ..:) what is the problem to add via..?
add stitching via for more connectivity between two layer...
Regards
Praveen Bhat
prastesh
Junior Member level 1
Bangalore
When you are copying via ,there options comes qty->give how many vias required in row and coloumn.Its easy way to add multiple vias.
