rayan zaher
Newbie level 1
i need code in C language to save data in internal memory of atmel 89c2051 microcontroller..so plzzzzz i need ur help :sad:
You don't mention which memory would that be. Because strictly translating the question, there is now difference between 89c2051 MCU and any other if it is about RAM. It is C we are talking about right? You just declare a variable (which obviously occupies memory space) and write values on that variable. Maybe you need absolute addressing? It would then help if you mentioned your compiler, so other members using the same compiler can help you.i need code in C language to save data in internal memory of atmel 89c2051 microcontroller..so plzzzzz i need ur help :sad:
