[SOLVED] C# During Execution of program I am not able to click any other button
rkt_167
Junior Member level 1
hi all,
I have build a GUI but I am not able to click any button during its execution give possible reason why i am getting this problem and also some solutions to overcome.
thanks,
hi all,
thanks,
is the focus locked onto some other component?
have you added event handlers to the buttons?
if so what happens when you click the button - nothing?
putting a console output in event handlers is useful for debugging, e.g.
private void motorONbutton_Click(object sender, EventArgs e)
        Console.WriteLine("motor on button clicked");
        motorON = 1;
        motorButton = true;
        motorPWM = false;
you can always remove it later
hi horace,
Right now I have used Application.DoEvents(); But its process is very slow.
Actually, I don't know much about event handlers do guide me more about it.
Do you know about background working in C#?
Thanks,
hi horace,
Thanks,
if you do a web search on C# GUI event handling it will give you plenty of links, e.g.
https://msdn.microsoft.com/en-us/library/aa983763(v=vs.71).aspx
I often use a background worker (in effect another thread of control) to carry out time consuming tasks - add it to the Form, create a DoWork event and start it in the Form constructor, e.g.
        public Form1()
            InitializeComponent();
            serialPort1.Open();
            backgroundWorker1.RunWorkerAsync();
again plenty of example are on the web, e.g.
https://www.dreamincode.net/forums/topic/112547-using-the-backgroundworker-in-c#/
