I'm not quite sure that this is the place to submit the question but any help is appreciated. Is there a way in virtuoso to import a netlist and
create from this netlist a schematic?
I don't think virtu0s0 (icms) can convert a (Hierarchy SPICE format) netlist to schematic.
Heard about EDIF netlist can be, but have no chance to try out.
Anybody can confirm it for us??
In Cadence, there is a tool - "CDL in...", it should be able to convert a spice netlist to a schematic. But I never find it work.
If the spice netlist is not too large, you can convert the spice netlist to verilog format first, then import the verilog netlist. The spice-to-verilog convertion can be done by a lot of program tools. One of such tool is awk.
Thanks for the replies on the issue.
I will test the "CDL in.." feature howere you are talking about a CDL (read spice) netlist converter to verilog (but then it's limited to digital).
I have heared about a "macro" language that exists in the c@dence environment, I believe it was called SKILL language or something. Is there documentation available perhaps to write in this language your own netlist to schematic converter? Does anybody got some descriptions regarding the structure of projects under c@dence?
Yes, there is a macro language called SKILL in C@dence. But I think it is difficult to position transistor in schematic view by SKILL. Verilog In can do this for us. So I convert the spice netlist to verilog first and "Verilog In" to get schematic. In this procedure, the bulk node connection and device parameters are lost. Then I use SKILL to recover these information.
Hughes, thanks for the tips. I certainly can use them to develop a magical bridge between 2 schematic captures (PC world and C@dence). Can you recommend some papers regarding this SKILL language? (be in mind that I'm a beginner )
I am sorry that I don't have any papers about SKILL language. I just learn it with C@dence on-line document. If your system is not installed with the document, here is a link, **broken link removed**
And do you need to "tune" your schematic database with the SKILL langauge when you have imported the EDIF netlist? As I remember
correctly you have 2 types of the language: EDIF200 and EDIF300. Are these described by IEEE? Or are there much dialects available?
