masoodpatel
Junior Member level 3
hello
can anyone guide to me write the code in c for measuring of temperature i got a code and i need to change according to it
#include <pic.h>
/* cADC - Display the PICkit Pot Input Value on the built in LEDs
This program samples the voltage on RA0 using the ADC and Displays the
value on the 8 LEDs using "cLEDDisp 2" as a base.
myke predko
04.10.03
__CONFIG(INTIO & WDTDIS & PWRTEN & MCLRDIS & UNPROTECT \
& UNPROTECT & BORDIS & IESODIS & FCMDIS);
int i, j;
int ADCState = 0; // Keep Track of ADC Operation
int ADCValue = 0;
int Dlay = 63; // LED Time on Delay Variable
const char PORTAValue[8] = {0b010000, 0b100000, 0b010000, 0b000100,
0b100000, 0b000100, 0b000100, 0b000010};
const char TRISAValue[8] = {0b001111, 0b001111, 0b101011, 0b101011,
0b011011, 0b011011, 0b111001, 0b111001};
const char NOTPORTA[8] = {0, 0, 0, 0, 0, 0, 0, 0};
main()
PORTA = 0;
CMCON0 = 7; // Turn off Comparators
ANSEL = 1; // Just RA0 is an Analog Input
ADCON0 = 0b00000001; // Turn on the ADC
// Bit 7 - Left Justified Sample
// Bit 6 - Use VDD
// Bit 4:2 - Channel 0
// Bit 1 - Do not Start
// Bit 0 - Turn on ADC
ADCON1 = 0b00010000; // Selemct the Clock as Fosc/8
while(1 == 1) // Loop Forever
for (i = 0; i < 8; i++ )
{ // Loop through Each of the 8 LEDS
for (j = 0; j < Dlay; j++); // Display "On" Delay Loop
if ((ADCValue & (1 << i)) == 0)
PORTA = NOTPORTA;
else
PORTA = PORTAValue;
TRISA = TRISAValue;
} // rof
switch (ADCState) // ADC State Machine
case 0: // Finished, Start Next Sample
GODONE = 1;
ADCState++;
break;
case 1: // Wait for ADC to complete
if (!GODONE)
ADCState++; // Sample Finished
break;
case 2: // Save Sample Value in "ADCValue"
ADCValue = ADRESH;
ADCState = 0;
break;
} // hctiws
} // elihw
} // End cADC
#include <pic.h>
myke predko
04.10.03
int i, j;
int ADCValue = 0;
main()
PORTA = 0;
// Bit 6 - Use VDD
PORTA = NOTPORTA;
else
PORTA = PORTAValue;
TRISA = TRISAValue;
} // rof
GODONE = 1;
ADCState++;
break;
if (!GODONE)
break;
ADCValue = ADRESH;
ADCState = 0;
break;
} // hctiws
} // elihw
} // End cADC
