seyyah said:
cameo_2007 said:A:
advantage- The supply voltage is entirely coming across the LED
disdv - transistor acts as an inverter.When i/p is 0,LED ON;when i/p is 1,LED OFF
B:
adv:no inverting happens.if i/p is 1,led ON and vice versa
disadv:The complete Vdd is not sourced to the LED as there will be voltage drop across CEjunction
nguyennam said:seyyah said:
I think there is fault in your circuits: it must be the n-p-n transistor in the first circuit, and the p-n-p in the second.
If that, so these 2 circuits are identical, only different from each other by the polarity of input control voltage.
The first needs the high-level (with respect to the minus terminal of the battery) while the second needs the low-level control voltage to switch the lamp on.
However, the second circuit is more preferrable in practice, for example, if you place it on a car, then the lamp-holder can be installed directly (without isolation) on the chassis which in the most cases connected to the minus terminal of the battery.
You can use the second circuit with the n-p-n transistor, but you have to apply the input control voltage higher than the supply voltage from the battery. That is impractical.
nguyennam
seyyah said:cameo_2007 said:A:
B:
You are wrong i think as simulation approves. Both LEDs are on when transitor is on (or base is triggered).
Added after 1 hours:
nguyennam
I know that i must use pnp in second conf. to activate the transitors by using different polarites. But i don't ask that. Both configuration works. Second configuration needs lower base current and has a bit more current gain. But VCE is much more than the first configuration and the transistor is not in the saturation region. This may be a disadvantage since it will dissipate more power.
I don't see any reason that, in the second configuration, a higher voltage is needed to turn it on than the supply voltage as you suggested. Can you explain it?
Somebody who has experince about these two conf. had said me that the second conf. causes led to blink sometimes. What may be the reason of this?
