biasing circuit in op amp
anhnha
Full Member level 6
I see that the biasing circuit below is used a lot in op amp design. However, I couldn't find any document explaining how it works. Could anyone tell me some document explain the operating principle of the biasing circuit?
Or could you explain it to me?
Thanks.
attachment.php
No, this is a CMOS PTAT (delta-VT) current loop, similar
to what you'll find at the core of a BJT based bandgap.
Your operating principle is that there's a single current
point where Vgs_m=4(I)+I*40K=Vgs_m=1(I), and the
mirror loop will lock to it (assuming it starts at all).
Beware the starup issues, since there is no explicit
startup circuit evident, and a relatively poor HF PSRR
as a result of weak unbuffered P and N current ref
rails.
Reactions: anhnha
    anhnha
Thank you very much for the explanation!
I think the top 4 mosfets is the improved Wilson current mirror that ensures the current at two branches are equal.
Is that right?
And could you suggest a better biasing circuit that is good as power supply voltage varies a lot and maybe, temperature also changes?
