-A3-
Newbie level 2
- Joined
- Mar 15, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- The Netherlands
- Activity points
- 1,293
I want to build 2x BIAS TEE to power relays and preamps with the following specifications:
1:
TX power: 100 Watt
Frequency: 1-60 MHz (HF + 6m)
Voltage: 12 Volt
Current: 1 Ampere
2:
TX power: 100 Watt
Frequency: 100-1400MHz (2m + 70cm + 23cm)
Voltage: 12 Volt
Current: 1 Ampere
Any of you with experience with building a bias tee for higher current and power can advise me about the L and C values?
1:
TX power: 100 Watt
Voltage: 12 Volt
Current: 1 Ampere
2:
TX power: 100 Watt
Voltage: 12 Volt
Current: 1 Ampere
