Can I apply an AC signal through a bias tee?
thundrous
Junior Member level 2
We are trying to apply 1MHz and 1V signals using a signal generator, through one port of bias tee.
I just wanted to check whether this is possible because usually, people use a bias tee with a DC signal.
dick_freebird
Advanced Member level 7
USA
That's the whole point of the bias-T, you have a DC
port and an AC port and a combined port.
Now, the DC port is inductor blocked and the AC,
capacitor blocked. So you can't push DC into the
AC (SMA) port, and any AC that can get through
the DC port (solder posts?) will be limited to very
low frequencies.
You should be OK with 1MHz into the AC port, but
check the specs - economics tends to make products
segmented to frequency ranges, and your port
blocking cap with 50 ohms Zout makes you a high
pass filter, while big caps' ESL would impose an
upper end to useful frequency. So "horses for courses".
The Mini-Circuits T I have, is good for 0.1MHz to 6GHz
so would be fine.
thundrous
low frequencies.
so would be fine.
Thank you very much for your response. I want to apply 1MHz and 1V signals using a signal generator with a Minicircuit bias tee built into the eVNA.
Do you think it would be ok if I use the eVNA bias tee itself instead of a separated bias tee like ZFBT-6GW+?
FvM
Super Moderator
Staff member
Bochum, Germany
Which signal do you want to combine with 1 MHz signal? If it's higher frequency RF, you want a diplexer rather than a bias tee.
thundrous
I want to sweep the frequency from 300kHz to 6GHz by VNA.
Right now I checked the 1v and 1MHz signal connecting to the bias tee of the VNA, and it seems it filters the signal (I checked it with an oscilloscope).
it successfully can transfer 1v and 5kHz but it is not enough for me. Do you think I need a Diplexer?
Any suggestion appreciated.
dick_freebird
USA
Can you be more clear about -which- bias-T port you are
trying to inject to? As I mentioned, the "DC" port will attenuate
HF (the BW limits rated, are for the "RF" port to "Combined"
port path). The "RF" port I imagine would be the VNA "input"
if there's a bias-T front end.
Yout test instrument may have limitations which a standalone,
wide-BW biast-T "nugget" does not?
thundrous
In this case, neither bias tee nor diplexer can work to add 1 MHz signal. A resistive "power divider" (6 dB coupler) would be my first approach.
Thank you for the response, but I need to apply two inputs one from signal generator and one from VNA.
To clarify, here is the video in which we do the signal modulation for one port of the VNA. As you can see we are sweeping the frequency from low to high (300kHz to 6GHz) meanwhile we are applying the 1V and 5kHz from signal generator to the bias tee built inside the VNA.
However, if I increase the signal to 1 MHz, bias tee filter the signal.
I am new in the RF field, but as long as the literature I have read I am kind of confused about using which of these passive devices.
--- Updated ---
Thank you very much for your response. here is the schematic of the bias tee built in the VNA:
we connected the signal of 1V and 1MHz to the bias tee port from the signal generator. and as I mentioned it filters the signal. However, if I change the signal to 5 kHz the signal modulation is successfully applied while the frequency is sweeping from 300kHz to 6GHz by the VNA. You can see the results in the following video:
Do you think if we buy a separate bias tee, we can do this signal modulation with 1MHz successfully?
Any suggestions are appreciated.
  • doc_2023-03-10_15-20-46.mp4
    780.4 KB
FvM
Super Moderator
Staff member
Bochum, Germany
Now you are talking about modulation, previously it was about "applying a signal", respectively adding it to another signal. The latter problem was precisely answered in my previous post: use a coupler.
A bias tee can add signals with distinct frequency difference but not modulate one signal by another. This can be e.g. done by a balanced mixer.
--- Updated ---
The video shows added signals, not modulation. So we are probably back to a coupler.
thundrous
--- Updated ---
Unfortunately, there are no RF mixers in the wide range of frequencies.
thundrous
y = x1 + x2 added signals
y = x1 * (a + x2) amplitude modulation
--- Updated ---
There are, but apparently you don't want a mixer.
What is your suggestion?
Sorry If I have not explained it very clearly, as I am new in this field.
I want to apply a 1V and 1MHz signal while sweeping a frequency from 300kHz to 6GHz. How can I do that?
thundrous
Use a resistive "power divider" (6 dB coupler) to add the signals. View attachment 181701
--- Updated ---
Do you think this model works?
--- Updated ---
--- Updated ---
It seems that the resistive power combiner sums the signals from each input port and deliver the resulting combined signal to the output port.
So does it mean that if I have a y signal and an x signal, the output of x+y?
if yes it does not work for me because I need the apply of both signals separately into my device:
1v and 1mhz
sweeping of 300khz to 6ghz
any suggestions are appreciated.
FvM
Super Moderator
Staff member
Bochum, Germany
1v and 1mhz
No idea what this means in technical terms.
--- Updated ---
It should be possible to describe the intended operation mathematically or with circuit.
LaTeX Commands Quick-Menu:
