spider7
Hello Everybody,
I WOULD LIKE ALL OF YOU TO READ PATIENTLY AND COMPLETELY.
I have fair working knowledge on Microcontrollers. I am trying to build a temperature controller for WAX POTs which requires some unique features. I have few basic questions to ask. We will talk about only basics avoiding any kind of application notes, Tuning Methods, Motors. We will talk about only Heaters which is 50VAC(which is unsual in this world). And medium in which it will heated is air. I am using K type thermocouple to sense the temperature. The Volume of the pot is roughly about 250-450 Cu.cm. I can program in C but NOT in assembly.
I know P, I and D. "P"= Proportional which the current error derived from Target Temperature and the Current Temperature. "I" is the integral and it is the accumulation of errors of the past. And finally the "D" is the derivative. Now here is it the past error or difference of current error and past error. Now if I put these things in an Excel sheet the temperature range from 30 to about 500 Deg C. And give a Set Temperature paramter and calculate as per the PID formula. There are various ones. I am using as described above. What I found is that the Output which (P+I+D) is always between 1-3 for any given Target (Iknow that this will be fed to Heater On/Off).
Now I have few question on PID as well as PWM.
1. Does the Integral becomes or limited to zero anywhere during the process( I mean in between the Set and Target) or we have to limit near to the target.
2. Here I would like bring some attention that any heater heats fast at lower temperatures and slow at higher temperatures(if air is the medium). Also the heater cools very fast at higher temperatures and slow in lower temperatures. If this the case then what is the use of output which is 1-3 always for any set point on the other hand where we require fast on/off condition of the heater at higher temperatures and slower on/off condition at lower temperatures. How can I overcome this perticular point if I am correct what I stated above.
3. Normal or rather all Process control introduces PWM signal to Heater. What does exactly the PWM do. I would like to have some good answer for this like explaining to a kid who does not know anything.
4. I know that finally it is said that tuning is the one for the success. But as I stated on point 2 above. How can we tune these conditions. Hence I don't think it is the tuning part which is important.
I think as of now without understand properly the above things I cannot proceed further. Hence I request all of you to enlighten me on these points. I will expect a good expert's explaination.
Thankyou all.
Thankyou all.
