iwkse
Newbie level 2
Hi, I'm studying electronics since little time, so excuse me if my questions are very basic but I guess you can help me to clarify dubts.
1. If I use a voltmeter and I measure a 4.5V battery, and I connect the COM cable to positive and Vohm cable to negative I get a negative number on the display. Is this normal? So it means there are n amount of electrons (negative sign) that still have to travel to the opposite side?
2. I was reading that resistance reduce the voltage..here I had a doubt because I though it reduces the current. Could you clarify?
Thanks!
Thanks!
