nuddin
Newbie level 6
cadence lvs fail
Hi all,
I am desiging a differential amplifier in Cadence. I did the extraction from layout and it was successful without any error.I made the circuit in schematic and am trying to check with LVS ( I'm using divaLVS.rul).
The problem I am facing is that whenever I start LVS run... it gives me a message "Job '.......'" that was started... (time) has failed.
And the error display it shows " '..........layout/netlist' is not valid. You must initialize the LVS run with a valid LVS run directory before you can probe"!!
I kept the run directory field as my design directory... I don't understand what should I change.
Can anyone pls help me regarding this.
Hi all,
