EEPC
Newbie level 6
Hi, I have a basic MOS common-drain amplifier as described below:
- Drain connected to 5 V DC
- Gate connected to an AC source on top of a 3 V DC source
- Source connected to a 200 uA current source with a resistor R connected in parallel. The parallel connection goes to ground, and the output voltage (Vo) is taken across resistor R.
If R approaches infinity, I heard someone explain that Vo > 3 - Vt - (Vgs - Vt)
where Vt = thermal voltage.
I'm not understanding how to get to this expression, because I had simply thought: Vo = 3 - Vgs, since it's just the voltage applied at the gate minus gate-to-source voltage. I'm not sure where the Vt comes from in the expression above.
Thanks for clearing this up for me!
