ajrox
Newbie level 6
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following lines to use the declarations that are
-- provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity txbuffer is
Port ( init,cs,rst,write : in std_logic;
data_in : in std_logic_vector(7 downto 0);
clk,w_clk : in std_logic;
busy,frame_done : out std_logic;
bit_out : out std_logic);
end txbuffer;
architecture Behavioral of txbuffer is
function crc_calc(CRC1 : std_logic_vector(15 downto 0)) --function to calculate crc
return std_logic_vector is
variable result : std_logic_vector(15 downto 0);
begin
result := CRC1;
for i in 0 to 7 loop
result := '0' & result(15 downto 1);
if(result(0)='1') then
result := result xor x"A001";
end if;
end loop;
return result;
end crc_calc;
type mem is array(0 to 255) of std_logic_vector(10 downto 0);
signal buffer1 : mem ;
signal count : integer range 0 to 255 :=0;
signal byte_count : integer range 0 to 255 :=0;
signal bit_count : integer range 0 to 15 :=0;
signal finalCRC : std_logic_vector(15 downto 0);
signal crc_send : BIT :='0';
begin
process(init,rst,cs,write,w_clk)
variable CRC : std_logic_vector(15 downto 0) :=x"FFFF";
variable data : std_logic_vector(7 downto 0);
begin
if(init ='1') then
busy <='0';
CRC := x"FFFF";
count <= 0;
frame_done <= '0';
bit_count <= 0;
crc_send <= '0';
elsif(cs='1' and cs'event) then
busy <= '1';
data := data_in;
CRC(7 downto 0) := CRC(7 downto 0) xor data;
CRC(15 downto 8) := CRC(15 downto 8);
CRC :=crc_calc(CRC);
buffer1(count)(10) <= '1';
buffer1(count)(0) <= '1';
buffer1(count)(9) <= not(data(7) xor data(6) xor data(5) xor data(4) xor data(3) xor data(2) xor data(1) xor data(0));
buffer1(count)(8 downto 1) <= data;
count <= count + 1;
elsif(rst='1') then
finalCRC <= CRC;
CRC := x"FFFF";
byte_count <= count;
bit_count <= 0;
count <= 0;
busy <= '0';
frame_done <='1';
crc_send <= '0';
elsif(write='1' and w_clk='1' and w_clk'event and crc_send ='0') then
bit_out <= buffer1(count)(bit_count);
bit_count <= bit_count + 1;
if(bit_count > 10) then
count <= count + 1;
bit_count <= 0;
else
null;
end if;
if(count > byte_count) then
crc_send <='1';
count <=0;
bit_count <= 0;
end if;
elsif(write='1' and w_clk='1' and w_clk'event and crc_send ='1') then
bit_out <= finalCRC(bit_count);
if(bit_count > 15) then
crc_send <= '0';
end if;
end if;
end process;
end Behavioral;
The above vhdl code is giving many signals as non-synthesizable-CRC,busy,count.
Can some one please help me?
Also can anyone suggest me some guidelines for synthesizble coding for vhdl
