amber_mittal
Newbie level 2
- Joined
- May 7, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,317
I am new to VHDL. Infact, this is my first attempt at writing a code. I wrote the following code for the downsampling of an image in VHDL.
entity downsampling is
Port ( clk : in STD_LOGIC;
din_ip : in STD_LOGIC_VECTOR (9 downto 0);
we_ip : inout STD_LOGIC_VECTOR (0 downto 0);
addr_ip : inout STD_LOGIC_VECTOR (3 downto 0);
dout_op : out STD_LOGIC_VECTOR (9 downto 0)
end downsampling;
architecture Behavioral of downsampling is
COMPONENT blk_mem_gen_v6_3
PORT (
clka : IN STD_LOGIC;
wea : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
addra : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
dina : IN STD_LOGIC_VECTOR(9 DOWNTO 0);
douta : OUT STD_LOGIC_VECTOR(9 DOWNTO 0)
END COMPONENT;
COMPONENT dwnsmpl_bram
PORT (
ena : IN STD_LOGIC;
addra : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
END COMPONENT;
signal sig_we_ip : std_logic_vector(0 downto 0) := "1";
signal sig_we_op : std_logic_vector(0 downto 0) := "0";
signal sig_en_op : std_logic;
signal sig_dout_ip : STD_LOGIC_VECTOR (9 downto 0) := "0000000000";
signal sig_addr_ip : std_logic_vector (3 downto 0) := "0000";
signal sig_addr_op : std_logic_vector (2 downto 0) := "000";
begin
sig_we_ip <= we_ip;
sig_addr_ip <= addr_ip;
ip_img : blk_mem_gen_v6_3
PORT MAP (
clka => clk,
wea => sig_we_ip,
addra => sig_addr_ip,
dina => din_ip,
douta => sig_dout_ip
op_img : dwnsmpl_bram
PORT MAP (
clka => clk,
wea => sig_we_op,
ena => sig_en_op,
addra => sig_addr_op,
dina => sig_dout_ip,
douta => dout_op
process(clk) -- din_ip, addr_ip, we_ip=1 then clk
variable count_ip: integer range 0 to 16 := 0;
variable count_op: integer range 0 to 16 := 0;
begin
if(rising_edge(clk)) then -- if rising edge => write and increment count
if(sig_we_ip="1") then
if(count_ip<16) then -- count=1 for first write, count =16 for 16 writes
count_ip:=count_ip+1;
end if;
end if;
elsif(falling_edge(clk)) then -- if falling edge => chng addr_ip , din_ip changes at falling edge
if(count_ip=0) then -- if falling edge bfr rising => do nothing
elsif(count_ip<16) then
sig_addr_ip <= sig_addr_ip + "0001";
elsif(count_ip=16) then
sig_addr_ip <= "0000";
sig_we_ip <= "0";
end if;
end if;
end if;
--write cycle finished--write cycle finished--write cycle finished--write cycle finished
if(count_ip=16) then --enable op_img
sig_en_op <= '1';
sig_we_op <= "1";
if(sig_we_op="1") then
count_op := count_op + 1;
end if;
if(count_op=0) then
elsif(count_op<8) then
sig_addr_ip <= sig_addr_ip + "0010";
sig_addr_op <= sig_addr_op + "001";
elsif(count_op=8) then
sig_en_op <= '0';
sig_we_op <= "0";
end if;
end if;
end if;
end process;
end Behavioral;
The image is stored in a BlockRam. After synthesising i got the following error:
"line 99: Signal sig_en_op cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release."
Can someone point out the mistake??? Thank you.
end downsampling;
PORT (
END COMPONENT;
PORT (
ena : IN STD_LOGIC;
END COMPONENT;
begin
sig_we_ip <= we_ip;
PORT MAP (
clka => clk,
wea => sig_we_ip,
dina => din_ip,
PORT MAP (
clka => clk,
wea => sig_we_op,
ena => sig_en_op,
douta => dout_op
begin
end if;
end if;
sig_we_ip <= "0";
end if;
end if;
end if;
sig_en_op <= '1';
sig_we_op <= "1";
end if;
if(count_op=0) then
sig_en_op <= '0';
sig_we_op <= "0";
end if;
end if;
end if;
end process;
end Behavioral;
