Backdoor programming SPRAM in Verilog
karthikw
I trying to do a backdoor loading of SPRAM, but I am not able write it externally ie I am reading 'X' once I write to the location . Please help me with it.
-Karthik
Check whether your chip_en,clock as well as write_en is active during write. Check whether your write protocol is correct.
Thanks.
I am trying to access the RAM directly (ie two dimensional array verilog memory model) under reset. I am able to do a backdoor load with initial block in the same verilog model file but once I try to do it externally in the reset phase it doesn't. I am using a verilog model of memory does chip_en, clock and write_en matter?
-Karthik
The memory model may check for X on either/both the address and write enable. Many of the models I've used force the array to Xs if either of those inputs go X.
