dpaul
Advanced Member level 5
For the more experienced SoC designers...
I need to implement an AXI interconnect which will support AXI4 and AXI4Lite. The AXI environment should be multi-master and multi-slave. The question is which one to get.
1> Xilinx Coregen can generate one for you. The following excerpt is directly from the spec, ds768_axi_interconnect.pdf - "The AXI Interconnect core is provided as a non-encrypted, non-licensed (free) processor core (pcore) in the Xilinx® Platform Studio (XPS) software. The core is also provided in the ISE® Design Suite for use in non-embedded designs via the CORE Generator™ tool flow."
2> I also have access to Synopsys DesignWare Library from which the AXI Interconnect IP should be possible to download (didn't check as of now, but making an educated guess).
3> Build my own
So which one is recommended?
3> Build my own
