AVR Tiny13 High voltage programming problem
luckym
Member level 1
Member level 1
Slovakia
avr high voltage programming
Hello,
I have a problem with programming Tiny13.
When I disable reset pin (fuse RSTDISBL=0), further programming is not possible. The programmer doesn't detect the device. I use this - high voltage serial programmer.
There is a errata in the datasheet about combinations of fuse bits that may lock device however I have avoided them.
Has anybody met this problem?.
thanks.
michal
