AVR ATMEGA16 timer0 , timer1 interrupt ,int0, problem
irfan ahmad
Full Member level 3
Full Member level 3
LAHORE PAKISTAN
i wat to use these interrupts at same time
1; timer0.
2; timer1,
3; external interrupt int0,
i have just enable two interrupts TIMER0 AND TIMER1 but malfunctioning.
if i enable only one interrupt timer0 or 1 then it works fine.
But when i enable both then only timer0 interrupt works.
here is my code.
#define F_CPU 8000000UL
#include <avr/io.h>
#include <util/delay.h>
#include	"avr/interrupt.h"
int main(void)
  DDRC=0XFF;
  PORTC=0X00;
  DDRB=0XFF;
  PORTB=0X00;
  _delay_ms(100);
  ////////////////////////TIMER FOR PWM CALCULATION
TCCR1A=0X00;	//NORMAL MODE
TCCR1B=0X01;	// NO PRESCALER
TCNT1H=0XC1;	//
TCNT1L=0X80;
TIMSK=1<<TOIE1;
TCNT0=0X06;	     // initial value
TCCR0=0X03;		 //TIMER0 CONTROL REGISTER
//TIMSK=1<<TOIE0;	when i comment this line then only timer0 works
  sei();					// ENABLE GLOBAL INTERRUPT
  while(1);
//////////////////////////////////PWM
ISR(TIMER1_OVF_vect)
TCNT1H=0XC1;
TCNT1L=0X80;
PORTB=~PORTB;
ISR	(TIMER0_OVF_vect)
TCNT0=0X06;	     // TIMER COUNTER REGISTER
PORTC=~PORTC;
please guide me .
Are you expecting interrupt in simultaneously? you can't, since it is sequential access
To enable both timer0 and timer1 interrupts
TIMSK[COLOR=#339933]=[/COLOR][COLOR=#009900]([/COLOR][COLOR=#0000dd]1[/COLOR][COLOR=#339933]<<[/COLOR]TOIE0[COLOR=#009900])[/COLOR] [COLOR=#339933]|[/COLOR] [COLOR=#009900]([/COLOR][COLOR=#0000dd]1[/COLOR][COLOR=#339933]<<[/COLOR]TOIE1[COLOR=#009900])[/COLOR][COLOR=#339933];
[/COLOR]
Enable timer0 interrupt
    [FONT=Tahoma]TIMSK[/FONT][COLOR=#339933][FONT=Tahoma]=[/FONT][/COLOR][COLOR=#009900][FONT=Tahoma]([/FONT][/COLOR][COLOR=#0000DD][FONT=Tahoma]1[/FONT][/COLOR][COLOR=#339933][FONT=Tahoma]<<[/FONT][/COLOR][FONT=Tahoma]TOIE0[/FONT][COLOR=#009900][FONT=Tahoma])[/FONT][/COLOR][COLOR=#339933][FONT=Tahoma]|[/FONT][/COLOR][COLOR=#009900][FONT=Tahoma]([/FONT][/COLOR][COLOR=#0000DD][FONT=Tahoma]1[/FONT][/COLOR][COLOR=#339933][FONT=Tahoma]<<[/FONT][/COLOR][FONT=Tahoma]TOIE1[/FONT][COLOR=#009900][FONT=Tahoma])[/FONT][/COLOR][COLOR=#339933][FONT=Tahoma];[/FONT][/COLOR]
set timer0 to 0x00
 TCNT0=0x00;
set timer0 with pres caller
TCCR0 = (1<<CS02) | (1<<CS00);
tern on timer1 ( you can change this as you wish )
 TCCR1B |= (1 << CS10) | (1 << CS12);
isr on
sei();
while loop
 while(true)
timer1 overflow
ISR ( TIMER1_OVF_vect){
port&=~port // your code
ISR ( TIMER0_OVF_vect){
hope this will help you
