Jester
Full Member level 6
I just completed initial testing of an audio device that I redesigned for someone. This device sends a low level signal to a PA or guitar type amplifier. Everything works as expected except that when the volume of the amplifier is set above say 1/2 volume, there is a noticeable high frequency hiss. I would describe the hiss as very similar to what you would hear when you adjust the tuner of an AM radio to a frequency with no signal.
This device has a very limited bandwidth 175 - 2400Hz, the noise is well beyond 2400Hz, sounds like > 7kHz or above.
The 2nd last stage is a 5th order SC filter (MAX7426) set to fc=2800Hz. Using a signal generator I plotted the filter response and the signal is 40mVp-p or less outside the pass band all the way up to 10kHz, the signal level in the pass band is adjustable and presently set to about 2Vp-p.
The output of the MAX7426 drives an op amp with a gain of 2 (that uses a 2.5V pseudo ground) that then drives the external amplifier with a series combination of 220 Ohms and 150nF to ac couple the signal output to the external amplifier.
Is 40mVp-p too much noise?
If so recommendations, to quiet it down?
