Thank you for the information. U191_3 is connecting to a different circuit. Is there any advantage to using this differential amplifier rather than an opamp?Which part don't you understand?
It basically looks like a differential input is amplified by two transistors and converted to a single-ended signal by the first opamp and then further amplified by the second opamp. (The second opamp circuit looks a little weird to me.)
There appears to be information missing. For example, there's a signal U191_3 that only appears in one spot.
