Atmega 8515 programming help
eehero
Full Member level 3
Full Member level 3
Libya
stk200 compatible dongle circuit atmega16
i am going to programmer my atmeg8515 Mc and i am searching for good
and easy parallel programmer for it
also i want to know the assembly instructions compatible with it is it the same
for avr family?
i am waiting for reply
8515 development board circuit
Hai
For burning code into your AVR, I think this will be enough.
AT90S8515 supported.
picstudent
programing 8515
have you tried ponyprog?
Use "CVAVR" which is software to debug your code and program it on avr.
also the easiest parallel programmer to build is stk200.
For parallel programing you can use STK500 development kit. You can try building yourself according to schematics or purchased at www.digikey.com at $79
For ISP programming (recommended) the Picstudent link it's OK
eehero said:
i want to know the assembly instructions compatible with it is it the same for avr family?
YES, you can read complete AVR Instruction Set (150 pages, updated nov 2005) : http://www.atmel.com/dyn/resources/prod_documents/doc0856.pdf
thanks all for reply
but are there any good programmer that using just
passive components(resistors,capacitors,..)
because the stk200 is not avaluable for!!!
STK200 it's a development board not a special programmer. You don't need STK200 to program your AVR microcontroller.
See for yourself the schematics of STK200. We get use to say STK200 compatible dongle when we're talking about ISP programmer.
Just build that circuit interface
and plugin into the PC parallel port interface.
Follow the link mentioned by Picstudent.
thanks much silvio i will try it and we will see if it is ok with me thanks at all
but i have a quesition, i read that the pony programmer was updated to program the atmega8515 but in http://www.lancos.com page i did not find the interfacing schematic for it!!
i just found the interfacing for At90s8515 is it the same?
eehero said:
is it the same?
Thanks silvio
realy i had confused, latest i were ask about the adaptor for atmega8515 for serial interfacing i had thoght that adaptors also for a parallel programmer
