tahertinu
Member level 4
- Joined
- Jun 11, 2011
- Messages
- 74
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Ahmedabad
- Activity points
- 1,752
hello, i am having problem interfacing 16x2 LCD with 89c55 controller i have used P0.4 to P0.7 as data and P2.0 and P2.1 as RS and EN respectively. I have connected 10K pull-up resistor with P0.but still i am not able to run on Hardware. Proteus run the code successfully. please tell me where I am Wrong?
CODE:
#include <regx55.h>
//Pin description
P2.4 to P2.7 is data bus
P1.0 is RS
P1.1 is E
// Defines Pins
sbit RS = P2^0;
sbit E = P2^1;
//Function declarations
void cct_init(void);
void delay(int);
void lcdinit(void);
void writecmd(int);
void writedata(char);
void writeString(unsigned char *);
void ReturnHome(void);
void cct_init(void)
P0 = 0x00; //not used
//P1 = 0x00; //not used
P2 = 0x00; //used as data port
//P3 = 0x00; //used for generating E and RS
void delay(int a)
int i;
for(i=0;i<a;i++); //null statement
void writedata(char t)
RS = 1; // This is data
P0 &= 0x0F; // Make P2.4 to P2.7 zero
P0 |= (t&0xF0); // Write Upper nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
P0 |= ((t<<4)&0xF0);// Write Lower nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
void writecmd(int z)
RS = 0; // This is command
P0 |= (z&0xF0); // Write Upper nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
P0 |= ((z<<4)&0xF0);// Write Lower nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
void writeString(unsigned char *s)
while(*s)
writedata(*s++);
void lcdinit(void)
///////////// Reset process from datasheet /////////
delay(15000);
P0 |= (0x30&0xF0); // Write 0x3
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(4500);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(300);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
P0 |= (0x20&0xF0); // Write 0x2
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
writecmd(0x28); //function set
writecmd(0x0c); //display on,cursor off,blink off
writecmd(0x01); //clear display
writecmd(0x06); //entry mode, set increment
void main()
cct_init(); //Make all ports zero
lcdinit(); //Initilize LCD
writeString("Hello World");
please help me out
CODE:
#include <regx55.h>
//Pin description
P1.0 is RS
P1.1 is E
// Defines Pins
sbit RS = P2^0;
sbit E = P2^1;
void delay(int);
void lcdinit(void);
void writecmd(int);
void cct_init(void)
void delay(int a)
int i;
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
while(*s)
writedata(*s++);
void lcdinit(void)
delay(15000);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(4500);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(300);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
void main()
please help me out
