wccheng
Full Member level 5
Hi Folk,
I am using TSMc013 PDK. As I use Assura41 to run DRC check, it give me "Failed to build VDB. Cannot submit DRC Run." In a CIW, it shows:
ERROR (AVRC-10275) : Edge input inddmy_ang2 and 'withSingularPoint' modifier is invalid.
\o 4723. errorLayer(geomXor(utm8r4_a utm8r41_b) "UTM8.R.4 Except for the inductor structure itself, all other active devices, passive devices, interconnect metal lines, dummy OD/PO/metals and vias are not allowed inside an INDDMY region. ")
\o ERROR geomConnect command cannot be nested ....
\o 5365. XXX( ... geomConnect((buttOrOver m7holed_mm lm7x_mm)) ...)
\o 5365. geomConnect((buttOrOver m7holed_mm lm7x_mm))
\o 5370. XXX( ... geomConnect((buttOrOver m8slt_t lutm8_t)) ...)
\o 5370. geomConnect((buttOrOver m8slt_t lutm8_t))
\o Errors exist in the rules file '/foundry/tsmc/tsmc013/tsmc013rf/pdk/designkit/tsmc13rf/pdk/designkit/Assura/./drc/assura.drc'.
\w *WARNING* Failed to build VDB. Cannot submit DRC Run.
How could I fix this problem? It is strange that it is no problem running under Assura317.
Thanks
Thanks
