dmitry_pr
Newbie level 5
Hi, all.
I use icfb 5.1.41, Assura 3.1.6 and UMC 0,18.
The DRC and LVS for my circuit is clean.
When I run Assura RCX, it says: Assura RCX run failed!
The log file says:
*Warning* avRCX: The LVS run used ?rulesFile, which overrides the technology directory operation. You must now use the rcxParameter ?rcxSetupDir <path/dir> in the rcxParameters section of the RSF to point to the directory containing the capgen files. A technology setting may be used in RCX only if technology was used in the LVS run.
Please advice me on this problem.
Thank you.
The log file says:
Thank you.
