emax00
I am having problem with Assura QRC settings. The DRC and LVS runs fine but when the QRC run form is opened, I cannot select the "technology" from the drop down menu (somehow it is disabled) and if I set the "Setup Dir" correctly, QRC runs fine with successful extraction. If I use QRC Setup... I can select the technology from the drop down menu and can save the setup but somehow it does not appear in the QRC run form.
I know this problem is similar to the IBM pdk issue discussed before and there is lot of suggestions for that on the web but none of them works for me. I am using IC615 and Assura412 on RHEL machine. Any suggestion to resolve this annoying issue?
