deepak242003
Full Member level 5
assura diode lvs issue
floating "nxwell" not allowed..
anybody got this error b4??
Deepak.
Deepak.
No. We don't let wells floating. You should check accurately! Could be lethal.deepak242003 said:anybody got this error b4??
Yes, in this case you may ignore it, because the nwell is self-biased. In order to inhibit the error message, you could stick a global name to it, like e.g. "biasp!" or "vddp!". I think this should disable the invalid error message.deepak242003 said:-!>|-!>|-
For the first diode I am getting this error... since the nwell(cathode) is not connected to any power ,we might be getting this error...
Can we ignore this error this time??
erikl said:In order to inhibit the error message, you could stick a global name to it, like e.g. "biasp!" or "vddp!". I think this should disable the invalid error message.
In layout should be sufficient, but I'm used to add names in both schematic & layout. Helps the LVS, and also helps you, if you would have to make changes after half a year or so ;-)deepak242003 said:should I add it in layout or netlist...
Depends on the PDK. Some want the very (same) layer, some want a PIN layer. Make it as you are used to, or simply try it!deepak242003 said:If in layout , wiht nwell layer ??
PS: I hope the diodes are operated in forward direction!? Serial connection in reverse direction wouldn't necessarily work well for symmetrical voltage division. And anyway you couldn't achieve a larger serial reverse voltage than the process allows for.deepak242003 said:-!>|-!>|-
