goodtime
Member level 2
assembly language
1. the instruction add ax,[0400h] find:
a. how many bus cycle (BC) is reguired for fetching?
b. how many bus cycle (BC) is reguired for executing?
c.assume that instruction is already in the quene , calculate the BC reguired for fetching and executing the instruction
2. repeat 1 for the instruction sub [DI+0500h],BX
( for 8086 anf 8088)
3. if AX=31h , BX=300h , content of location 2000h:400h and 2000h:401h are 0ah and 06h , DS=2000h and CS=2000h . find the content of AX after executing the instruction
ADD AX,[BX+0100h]
4. the instruction SUB[BX+300],BL
assume [7000h:510h]:28h
BX=210h, CS=7000h
find:
a. number of BC reguired for fetch and execute?
b. value of F register?
c.[BX+300] after execution?
d. value of IP registers after execution the instruction ?
5. write a program to add number a (24bits) with number B of the same size and store result in 1000h:0106h . assume number A and B are stord in memoy location starting at 1000h:0100h repectively
plz plz any one can help meeeeee
ADD AX,[BX+0100h]
BX=210h, CS=7000h
find:
