assebly code of temperature using LM35 and Pic18f452
fooofaaa
Junior Member level 1
Hi for all;
I'm a graduated student. and I need to interface pic18f452 with the lcd to read the degree of the temperature using LM35 Sensor. I want the the assmbler code or MicroC code Or MicroBasic. I'm try a code that was posted here. But it is give error when I use MicroBasic or MicroC.
I will attached The File and the desgn....
Please >>> any one can help me ???:cry:
What you attached seems to be codes that I had posted, am I right?
What do you mean by error?
Yes, You are right :)
I try to connect with you But I don't have any way.
If I upload the hex file to the Pic i don't have any read!!
also If i apply the code in MicroC I have the Arror as in the attach file
Re: assembly code of temperature using LM35 and Pic18f452
Hi Tahmid,
do ypu see the error?? I'm watting you answer!!
please help me if you can do that :cry:
