Arbitrary pcb shape design using Altium Designer
rizwan183
Member level 4
Pakistan
i am looking to design a PCB antenna using Altium Designer. But i could not figure out how to design an arbitrary shape such as circle in Altium. Any suggestions?
you can draw any shape in altium. example you can use "Place>Full circle" command for circle. You can make Arc, straight line, etc., Make sure you have selected a net from the object property menu(By double clicking the object). Another way, you can import 2D outline from anyother software in DXF format and pour "polygon" inside the layout.
Draw any closed loop 2D outline (Example : Full circle), select the entire object & follow this. Tool>Polygon Pours>Define from selected objects
First Of All Thanx for your response. For me first method somehow worked to design something like attached though not look like a proper way. And as for as DXF format i tried a single 2D circle export it using HFSS options. But this didn't worked. I don'nt know why. If you have some practice material related this Do share the links. And One More question how can i define my board shape to be round? Thank You
Draw a circle with the desired diameter, select it, then click "Design" => "Board Shape" => "Define from selected objects". Alternatively, draw the shape you like in your favorite CAD software and then import it into Altium as a STEP file. You can then use the same technique to define the board shape from the STEP contour.
If you want to design a circular PCB, this is the best method. But you should draw in mechanical layer.
Actually my issue is to draw multiple void circles ( areas without copper) of radius 0.49 mm inside a bigger copper circle as shown in my second post. Poly gone pour commands does not work properly in here. Issue is precision. If I use polygon pour command the results would be inaccurate because of High frequency. Can I do this using Altium? If so, how is this possible? The issue with dxf file import error is dimensions of the document too large and as for as the step file does not supported by Altium. Kindly help me on this.
As I understand if you need only the circular copper tracks, you can make it with simple circle command with very good precision. If you need any other odd shape, its always better to use a DXF file format. If possible give me a required shape information in drawing format.
Udhay
Dear Udhay, I have attached the a rough Design.in this white circles corresponds to copper free areas with a radius of 0.49 mm and the bigger circle is 32 mm. Black area represents copper. if we define a circle and then use a "polygon pour=>Define for selected objects" then it give a circle having copper free area in the mid and between the circle and and 2D circle obtined from Polygon Pour as dimensions (0.49mm) is comparable to the line width.
what about 32mm circle with 1mm drill hole?
It's actually not my choice. with that much variation Response changes drastically because of high frequency.
Making 0.49 dia is very critical. Very much possible with drill hole. Check this...
How you take these exact measures. Is it using polygon pour command and consider the null effect of the command before hand.And Thanks a lot buddy for you Help I am able to use .DXF format.
