any good microcontroller with lots of flash/ram inside?
ahgu
Full Member level 3
Full Member level 3
microcontroller ram
something like 256K/32K? need a little controller that has everything to save space. prefer more than 16bit data bus. 8 bit is ok too. 32bit is a over kill for me.
wutc
Newbie level 5
Newbie level 5
8bit atmega uc with 2k ram
You can use TI's MSP430F1121 that have 256B flash memory and 256B ram
Best regard!!
jjchl
Newbie level 6
Newbie level 6
spain
Hi
This could help you???
ATmega128/L :
128k flash, 4k EEPROM but only 4k of RAM.
hxxp://www.atmel.com/atmel/products/prod199.htm
neuralc
Full Member level 4
Full Member level 4
atmel versus mitsubishi microcontroller
Hi all,
What about PRICE / FUNCTIONALITY relation?
NeuralC
Gunship
Member level 2
Member level 2
atmega256 adc khz
Another way to do it is use a good 8051/8052. Add a waferscale WSI chip on it. You can get one with LOTS of flash and RAM. They are usually inexpensive. That is a good combination if 8-bit is OK but needs lots of storage.
Gunship
ahgu
Full Member level 3
Full Member level 3
microcontroller 8051 with 256kb flash memory
what is the wsi? where do I go look?
zohar
Junior Member level 1
Israel
high speed ram for microcontroller
The Waferscale company bought by ST,
for more information regarding PSD devices, look at:
You can use it with all MCU8051 platforms, if you need help PM me.
zzz
calvinhorng
Member level 4
Member level 4
c_augusto
Newbie level 6
Newbie level 6
samsung flash m32c
Try with the Mitsubishi M30624 it has 256 kByte of flash memory, it's programmable in-circuit and it has 20k of RAM. It has, also the possibility, to operate as MCU or as CPU (in this way you are able to manage memory up to 4MB).
This uP, for me, is quite good, and you can find all you need for the use on the web (the programmer is a simple MAX232 connecter to the CPU with a few resistors).
All the best
arturt134
Full Member level 2
Full Member level 2
Poland
arm cpu 256k internal flash
Try Hitachi H8S series. They have up to 384kB flash and up to 32kB ram memory. It should be sufficient.....
Regards
Stark
Member level 2
Member level 2
puc3030a
hitachi h8s or mitsubishi M16 series are good choiches
Stark
sunjimmy
Full Member level 2
Full Member level 2
microcontroller 256kb ram 4mb flash
MT6759 is another alternative you may consider for cost/performance.
64K byte MTP-ROM
512 byte SRAM
8-bit 8051 with 40MHz clock
nukhung
Member level 2
Member level 2
microcontroller arm7 sector protection
You try considering T89C51CC01 from Atmel :)
venz
Full Member level 2
Full Member level 2
microcontroller with 2mb ram
why not Motorola HCS12 Series?
Up to:
512kB Flash,
12kB RAM
4kB EEPROM
2 x SCI
3x SPI
2x CAN (one even has 5x CAN)
IIC
16 channel 10-bit ADC
50MHz Clock (25 MHz BUS)
8 channel 8-bit PWM (Or 4 channel 16-bit)
Package 80-pin QFP or 112 LQFP.
Voltage: 5V.
The MC9S12A128B goes for some $20,- i think(maybe $25,-)...
almtree
Junior Member level 2
Europe
wutc@atmel.com
Hi
Go for the Hitachi h8s or the Mitsubishi M16. Greate suport, almost free compilers, lots on info on the sites. I personally use the M16c , and for smaller projects the AVR's, but the M16c is a joy to use :lol:
Regards
Paulo A.
shell3
Member level 1
Member level 1
tmp95fy64 price
The Zilog eZ80F91 has 256KB Flash + 8KB high speed RAM and
a 10/100BaseT Ethernet MAC
