Any good book on analog design
satyakumar
Full Member level 3
Bangalore
easy understand razavi allen
Any body has good book on analog design?
h ehe eh ehe !
many, many, m. . a . . n . . .y for U ! This is this first.
Hi:
In general, you can refer the website: **broken link removed**
Good luck^_^
analog design essential is very good.
Hi
"Analysis and design of analog integrated circuits" by:p.Gray, Meyer, Hurts
you can find the book and also solution in e-book section.
good luck.
Design of Analog CMOS Integrated Circuits, Behzad Razavi
I also recommended the book by Razavi .
I read once and once and learned more and more
Any book you read carefully is the best.
you can read one of these books:
Gray, Razavi, Allen
I think baker's book more better,I have read two times.
Johns and martin is also nice especially for analog design.
I think first you should take a basic book which would be base on theorectical concept like Jacob Baker, and Johns and martin.
Then you can go for mathematical concept like
Best of luck!
CMOS: Circuit Design, Layout, and Simulation,
J Baker
Behzad Razavi
Do you mean book for Analog design or Analog IC design?
There is a bit difference....when you are dealing with analog design you usually deals with packaged IC and building applications with them. (for example, you take an op-amp and build a filter...). In Analog IC you are usually deals with transistor level and not in compact model.
this is my favourite: Gray, P.R. & Meyer. R.G.,Analysis and Design of Analog Integrated Circuits (3rd Edition), Wiley (1992)
