sutapanaki
I'm using cadence IC6.1.4. I'm trying to annotate the operating point information on the schematic for the transistors and I can't. Transistors are defined as primitives, not subcircuits. Similar to the nmos and pmos from analogLib (for which I can annotate the op). I can annotate the node voltages but not the id, vgs, vth, gm etc. However, Results > Print >DC Operating point works fine. I know I should probably use Tools > CDF>Edit but that's as far as my knowledge goes on that matter. Can someone suggest what I should edit so I can annotate the schematic.
Thanks
Thanks
