Amplifying output signal from 5V using load cell
mf1364
Full Member level 3
hi dear friends
i have a load cell and i want to amplify output signal from 5v,that mean i want when i push load cell the output signal increase than +5v and when i pull it the out put signal decrease from +5v . i try several circuit for that but i cant earn any good result .do you have any practical circuit for me?:cry::cry::cry::cry::cry::cry:
load cell output
What types of circuits have you tried? What results are you getting?
If I understand you correctly, it looks like you want to have a digital output: 0V if the force is blow a certain threshold, +5V if it's above the threshold. You would need a to have comparator somewhere in your system.
741 loadcell amplifier circuit
If kender is right, I guess you need a difference amplifier (opamp) and a schmitt-trigger (also opamp).
Combine those two :D
ad524+circuit
tanks for your guidance but i think your circuits is not practical , and i tried with some
op amp circuits and i could amplify the output signal but i want output changes from +5volt , you know i want a practical circuit that can control and amplify output together. :|:|:|:|:|:|
load cell practical ckt
I'm not sure I fully understand the problem. A tip is that ground symbol on the substractor circuit doesn't need to be 0 volt.
Another thing is that you might need an instrumental amplifier.
https://en.wikipedia.org/wiki/Instrumentation_amplifier
In my first reply I added a schmitt-trigger, but I don't know if you really need it.
Maybe if you explain once more the aplication of your circuit, I can help. Eg: What voltages does your load cell output (in details)? And what output voltages do you want? 0-5Volts?
load cell to instrumental amplifier
DEar fellow,
i did this project 3 years ago, i used Instrumentation Amplifier .... u can use any instrumentation amplifier from Analog Devices
i developed this for Cement factory,
~AM
ad524 to load cell
you need a instrumentation amp for this .... because load cell max output woukd be say 10mV , for full scale deflection . u need ad7796 to amplify the signal ....... and then convert from adc ........go for ad7796 datasheet.... everything will be clear.........
hi ,
i have an model uu-k100 ,that has 10mv-50mv out put but you know i want amplify signal around 0-10v and when i pull or push(Press) it i want to have out put signal changes from +5volt.
for example :this cell when i press it powerfully output is around -4mv and i want convert it to a number below +5v(until 0v ) and too when i pull it powerfully output is around 50mv i want convert it to above
+5v(until 10v). :D:D:D:D:D:D:D
Added after 1 hours 56 minutes:
ashad said:
DEar fellow,
~AM
hi
i tried this circuit in https://en.wikipedia.org/wiki/Instrumentation_amplifier but unfortunately i had no success and output signal had not any change after 7oKgf .
and i want it changes until 100kgf linearity.
can you send your circuit for me :?:
load cell op amp circuit
Any Body Help me??????
plz help me .................
i try,,,, make this amplifier with AD524 but i dont have any good result.......
my problem in this circuit (Ad524) is noise......
it means that output of my circuit have noise and a-stable........
help me plz..................:cry::cry::cry::cry::cry::cry::cry::cry::cry:
