amplifying dc signal for measuring
elpajuo
Junior Member level 2
I have a low current circuit where I want to log the current every 10s for a long period of time
The current jumps from about 100uA to 25mA.
I have a data logger that can log from 0 to 20 V, so I can add a 1 ohm resistor with the volt logger to measure current but it needs to be much higher.
If I amplify the current with a gain stage of 200 from 25mA to 5A, how can I revert back to normal operating current of the circuit? do I need a buffer stage?
My focus is on being able to read when the 25mA signal is on with the datta logger, the 100uA can be shown as 0 and does not matter
Input appreciated
You can use a differential amplifier assuming that the input voltage is in the opamp range
The gain is set by Rf/R1
or you can use an Instrumentation Amplifier like AD620
(AD620)
You can use a shunt resistor that creates a voltage drop with the current and then use any of the above to amplify the voltage
Alex
Thanks for the reply
Ok, so I can use the op amp to make the gain into something noticeable for the datta logger.
I am trying to measure how many times a battery powered device goes into sleep mode (100uA) and transmit mode (25mA) over a long period of time with the data logger. So once I amplify the signal to eg 5V how can I lower it back to the 25mV range in order for the circuit not to get damaged?
This is what I am thinking of
I only have access to the two battery terminals which receive a constant voltage under normal operation.
What will be damaged?
For example with the 1ohm resistor and a differential amplifier with a gain of 50 you can get 0.025*1R=0.025*50=1.25v
this can be easily detected from your logger.
Alex
I mean something like
assuming that the battery - is also the ground
I was thinking using a low input offset comparator - if you just need to know low (uA) or high (25 mA) levels.
