breadbord
Newbie level 3
I have some questions about altium.
I created a footprint for a Xbee module.
The pads i created are multilayer but when i do a print job (smart pdf) the holes for the component are on the top layer.
When i change a pad to bottom layer, the pad is on the correct layer but i don't see the drill hole anymore.
Here you can see some printscreens:
https://i49.tinypic.com/2641ff6.png
https://i48.tinypic.com/258ml4p.png
When i place a standaard 2 pins header from the connector library the pads are also multi layer.
How can i change the pads to bottom but with correct drill holes ?
Printjob printscreens:
https://i46.tinypic.com/5x0v4k.png
https://i47.tinypic.com/309oh8m.png
Thanks in advance,
Breadbord:-D
Thanks in advance,
Breadbord:-D
