Altera Cyclon 3 150MHz clock input
sherif123
Member level 3
Member level 3
I want the internal operation of the FPGA to run on 150 MHz. I can find clock oscillators that run at this rate. Is this approach good for the FPGA or should I just use a low frequency oscillator like 10 MHz and then use the internal PLL of the FPGA to generate the 150 MHz clock?
Thanks
It depends on the FPGA. But 150 should not be a problem I suppose. You can use this clock directly.
