abhi@eda
Member level 1
Simple question about on how much Torque is necessary by a DC motor to rotate a rotor arrangement..
This image below sums up my question more clear,its a hypothetical setup i know,but its just for my understanding
the length of each blade being 1.5 meter
As you can see,there's a electric motor,and it is connected directly to a shaft,and that shaft is connected to 3 blades ,where each blade weighs 1.5 kg,i know a gear can be used to increase the torque or increase RPM..but i want to understand it without confusion...
i want to calculate what amount of torque is to be produced by the motor to rotate the shaft,the torque reduces as the RPM goes up,but i want to find the initital torque needed to move it...
i want to know the steps or algorithm you could say
should i calculate the moment of inertia? or..?
please tell me the algorithm to calculate ,ill do it my self and try to find out the answer..thank you
the MI of the each blade
the weight of the each blade is 1.5 kg/14.7 Newtons
and the length of blade is 1.5 meter
therefore MI = (14.7 X 1.5^2)/3=11.025 Newtons
and as there are 3 blades its 11.025 N * 3 = 33.075N of total Moment of inertia on the rotational Axis..
so now the DC motor has to produce more than 33 Newtons per ... ?
so that it rotates the shaft a 0 RPM ,and if i produces any torque less than 33 Newtons per ... then the motor stalls and will never be able to start the rotation by itself..
am i right about this?
please correct me,this is aching my head,i am not from physics background...
