ADS layout simulator for quasi yagi upper conductor
abdoeng
Advanced Member level 2
ADS simulation
hi i import quasi yagi upper conductor to ADS layout simulator ,there is any facility to construct dielectric layer with its thick or the limited ground dimension since it say that move only at x or y in other word how can i move at z axis.is there is A FDTD program that simulate quasi yagi antenna ,if there pls upload it.
thanks guys
Re: @DS simulation
abdoeng said:
hi i import quasi yagi upper conductor to @DS layout simulator ,there is any facility to construct dielectric layer with its thick or the limited ground dimension since it say that move only at x or y in other word how can i move at z axis.is there is A FDTD program that simulate quasi yagi antenna ,if there pls upload it.
thanks guys
ADS is a 2.5 D simulator and you cannot draw physically the 3-D structure in its layout editor; but while performing Momentum simulation, you can define the dielectric substrate parameters (Er, thickness, tand etc) substrate thickness by using the Momentum>substrate>create/modify option in the layout window. You can add any number of substrate layers and conductor layers using this facility. The only problem with this is the bottom ground plane is infinite by default and the simulator does not account for conductor thickness in the analysis. The good news is that in ADS2004 the conductor thickness is also accounted for.
