jdstavares
Junior Member level 2
I designed a rectifier circuit, and verified every mlins and components to not be overlaped. However when i generate the schematic from layout one of the cpads gets offset being misplaced over the layout. How can I put it the right place?
I already forced the nets to be exactly as the schematic.
Also, in some components I noticed that a yellow triangle - like a warning sign - appears. I click on it and it does not explain the reason for it appearance. I thought it was due to some overlap, but at the beggining, when testing to place each component at a time from the schematic to the layout, that also happened, so not really sure about the reason why.
And about the clearance, is there a minimum value? I saw some papers, that claimed that the 3w rule is not necessary, so that I can just put some value, but did not fully understand it...
Can anyone help me?
Thank you!
Can anyone help me?
Thank you!
