Hi all,
Could anyone provide some tutorial/advice how to design an impedance matching section using the Impedance Matching Utility (IMU) of ADS when S-Parameter files are available? Say, I have two S-Parameter files/blocks which I would like to match to each other with a defined bandwidth and loss, so I am using the LC_BandpassMatch Smart component and the IMU for this purpose. It then calculates some possible matching networks but when I implement the circuit as a whole (Input --> SP_Block1 --> ADS_Matching --> SP_Block2 --> Output) it does not seem to provide the desired broadband matching at all.
I tested this by terminating the SP2_Block at 50 Ohms and looking at the input impedance of the combination ADS_Matching/SP2_Block, which should be more or less equal to the complex conjugate of my SP1_Block output impedance over the desired bandwidth when the input is terminated at 50 Ohms, but it is not the case.
What am I missing here? Any tutorial or info will be of great help.
Thanks!
