It's possible that your circuit oscillates at around 75 GHz and in Transient simulation the circuit's performance is affected by this oscillation. Check your current and voltages and check for beginning s11 and s22 if their magnitudes become positive at around 75 GHz.
voltage gain or power gain? S-parameter simulation is only a small-signal analysis, while transient includes large signal analysis. Nevertheless, check your current and voltage waveforms from transient analysis.
Just in brief, from your first diagrams (transient ?) oscillation is visible. Second diagram, the voltage gain = 20*log (x) not 10*log (x), did you roughly calculated your voltage gain of your ideal common base ampl with gm*Rl?
By the way, for s-parameter analysis place proper dc-blocks and dc-feeds at your sources and terminals.
And last thing to remind, s21 is the forward voltage gain under matched (Zref) condition. I attached an ideal simulation with calculation of s21 and voltage gain, you see it works under matched conditions, otherwise it is not comparable.
Thank you for your help.
i have some questions.
in your circuit, load R is very large.
because check output voltage, Open circuit setting ?
my goal is check demodulator's performance.
and i need amplfying before demodulating.
if i connect amp with demodulator(input R is 50ohm) instead load, gain will be change ..
The load has a high value because of the high output impedance of the ideal transistor and to meet the matching and show the relation between s21 and voltage gain. I justed wanted to show that you can only compare s21 and voltage gain under matched condition.
Is your demodulator a real circuit? Maybe it has some additional reactive input impedance, if you connect a simple 50 Ohm resistor, its characteristic is constant over frequency and includes no reactive components.
I'm sorry very late.
I tried many things for finding difference between HB and TRAN.
I checked other components.
R, C, L show same results.
But transmission line and transistor show differences.
I attach results of transmission simulation.
I made a very simple circuit for test.
This S21 exactly same with result of SP-Sim.
left is HB ans right is TRAN results.
I tried to deduct same Vout, Vin, Power Gain, very hard to me.
Is there some errors ? or mistakes ??
I don't know why transmission line and transistor have difference between HB and Transient.
i attach other result(change to 50ohm transmission line) <- this is HB result <- Transient result
i think i miss something when simulate transient sim ..
And I find some problem.
it's okay until 250GHz.
but 250.1 GHz , it's strange
I can confirm the problem, it's the the ideal tline component, if you set F till 250 GHz, everything fine, 251 GHz you get problems. If you take instead the TLIN4 component everything works fine, also for 300 GHz. Later more.
