[SOLVED] ADS and HDL cosimulation problem
my8os
Junior Member level 3
Hi, I've successfully been able to cosimulate via Ptolemy an HDL component I designed with other ADS blocks using HDLCOSIM component single input port and single output port. However, I need to use multiports and the manual says that it is supported as string arrays.
When I declare the outputs in HDLCOSIM e.g. "output1" "output2" (followed by a BUS SPLIT component) I get an error message that HDL port output2 has not been connected to any ADS component port.
I tried various combinations in declaring the string array with no success.
Any ideas?
---------- Post added at 16:30 ---------- Previous post was at 16:17 ----------
Had a brainstorm as soon as I posted and it worked:
I had made a mistake by connecting a simple wire between the multiport output and busplit instead of bus. Problem solved!
