bharat_tangudu
Member level 1
I am trying to design the fully differential opamp. I put all the values according to mathematical calculation and put those values in simulator. After some simulation, some transistors are going to linear again against the calculations. I found a very high value of common mode voltage at output node. I tried all the means to get all MOSFETs into saturation. But i was not able. Can somebody suggest how to make these into saturation and setting output commonmode voltage to VDD/2
I am attaching the schematics
